Ran out of gas, no spark.
Old Oct 2, 2007 | 8:33 PM
jcammarata's Avatar
Default Ran out of gas, no spark.
04 Chevy Silverado 1500
Yesterday I ran out of gas right as I pulled into work and I filled it up with a five gallon gas tank to get to the nearest gas station. The truck started up on the second try and I let it idle for a minute and it stalled out. I started it back up ran it for a minute and headed home were it stalled out again. I pulled over waited a few seconds and started it again. I made it to the gas station where I got 14.5 gallons of gas and headed home. So the next day I started the truck right up no problem, but I noticed the truck occasionally bucked and after 5 minutes I lost power and the truck stalled. Now the truck won't strart at all. It tries to turn over but won't. I wasn't sure if there was air in the line and if that would cause the truck to stall. Also we checked the fuel line before the intake and we have fuel. We can hear the fuel pump initiate and all fuses are good. The only thing I can think of is a faulty fuel pump relay...maybe something with the distributor, spark plugs(not sure how old they are), ignition module, clogged fuel filter, or maybe there is something small I am not doing, any suggestions are appreciated.
JC
Old Oct 2, 2007 | 11:19 PM
RonH's Avatar
Default RE: Ran out of gas, now engine won't turn over.
Since the problem started when you ran out of gas, I would start looking there. Maybe a stopped up filter or a bad fuel pump. The pump is supposed to be submerged and when the tank goes dry, the pump can be damaged. Have your fuel pressure checked at the check fitting on the fuel rail behind the throttle body. Good luck.
Old Oct 2, 2007 | 11:23 PM
monteash's Avatar
Fuel pump is most likely culprit. Especially true if it is an old pump.
Old Oct 7, 2007 | 11:07 AM
jcammarata's Avatar
If it helps I get no spark using a tester direct from the spark plug wires...just replaced the ignition coil, used a jumper to ground it (didn't bolt into bracket just trying to test it) and still no spark at the plugs does it have to be bolted into the bracket to get the proper ground? If anybody can think of anything else that would prevent the plugs from giving spark I would appreciate it.
Old Oct 7, 2007 | 2:45 PM
RonH's Avatar
Have you looked into the distributor to make sure everything is OK in there? Have you tested the coil wireto see if it's firing to the distributor?
Old Oct 9, 2007 | 4:49 PM
jcammarata's Avatar
So it turns out after all that it was a faulty cable that powers the ignition coil. When we first tested it we had power but bend it just the slightest and BAM no power, no spark.
caddieb
May 15, 2011 5:32 PM
truthstar
Jul 8, 2010 4:28 AM
chevy_smoken
May 18, 2010 7:02 PM
dand1966
Uplander
Aug 31, 2009 3:54 PM
sbbrown
Mar 3, 2007 9:16 PM
