Rear Door Locks Won't Lock/Unlock??
Old Jun 8, 2007 | 10:40 PM
drjimbo's Avatar
Default Rear Door Locks Won't Lock/Unlock??
Just bought a new body style20072500HD LTZ Crew Cab and noticed the rear door locks will not lock/unlock with the driver/passenger controls or with the keyless entry. I have to lock/unlock them by hand. It is obviously still under warranty and I can take it in butI wanted to see if there may be somethingI could try first. I checked all the fuses and the Driver Information Center options.These were all OK. Any suggestions before I take it in? Thanks.
Old Jun 9, 2007 | 5:26 PM
Old Coot's Avatar
Default RE: Rear Door Locks Won't Lock/Unlock??
Check page 127 of your owners manual. I think that addresses your question.
Old Jun 10, 2007 | 1:43 PM
drjimbo's Avatar
I tried changing the safety locks all sorts of ways. Still nothing. Any other suggestions? Could a "relay" or "swith" be out? Thanks.
Old Jun 10, 2007 | 6:23 PM
Old Coot's Avatar
I have the extended cab, and was having that kind of problem with the rear windows. Found a switch on the drivers side arm rest that turns them on and off. When off you can only lower them from the drivers seat. I thought that was the kind of problem you were having.
Old Jun 10, 2007 | 6:51 PM
drjimbo's Avatar
The onlyswitches I seearethe window lockout switch, up/down window switches, lock/unlock switch for doors,and mirror switches. Is there another one? Thanks.
Old Jun 10, 2007 | 7:52 PM
Old Coot's Avatar
I was talking about the window lockout switch. I thought at first something was wrong with the switches on the rear doors till I found that switch.
Just in front of the lock switch. Sounds like you have pretty well looked it over.
Old Jun 10, 2007 | 11:01 PM
drjimbo's Avatar
Ya, I think I've tried everything. I guess I'll have to get it fixed when I pick my plates up. Thanks for trying.
polpower
Aug 19, 2013 10:42 PM
kaner
Sep 10, 2010 10:30 AM
davbell22602
Mar 10, 2010 8:36 PM
G-Force
Jul 20, 2009 3:18 PM
98greenventure
Aug 9, 2007 7:41 PM
