Is the rear end blown??
Old Mar 13, 2010 | 4:28 PM
  #11
nauticstar87's Avatar
Go to a junk yard. I blew the rearend outta my F-250, got lucky and bought a freshly rebuilt Dana 80 with a Detroit Locker, for $150... I kinda screwed 'em on that deal.
Old Mar 13, 2010 | 4:53 PM
  #12
maxxman04's Avatar
kinda?! frickin thief
Old Mar 13, 2010 | 5:09 PM
  #13
halftonornone's Avatar
will an older style silverado or sierra half ton or maybe 3/4 ton work with my set up. i know i have disc brakes and not sure of the older ones..3/4 ton would be sweet
Old Mar 13, 2010 | 5:34 PM
  #14
Get one with disc brakes. Your truck is set-up to run 'em, might as well keep 'em.
Is your truck 4WD? if so, make sure you get an axle with the same gears.
Any 10 bolt from a 1500 should work. You could get a 14 bolt from a 2500. But you'll be running 2 different sets of wheels.
Old Mar 13, 2010 | 5:46 PM
  #15
where the older style disc brakes? i dont know what kind of axle i have. how can i tell? its a 2000 4wd 4.3 auto..
Old Mar 13, 2010 | 5:50 PM
  #16
You have a 10 bolt, but seeing how its 4wd, you'll want to make sure you get an axle with the same gears, or you WILL break a lot of stuff.
The way to tell the kind of axle you have, count the diff cover bolts... you have a 10 bolt.
The way to tell your gears, is to look in the glovebox for the RPO codes. In the general tech section there should be a sticky with a breakdown of the codes, if not post it here, and me or someone else will be able to help you out.
I don't know when disc brakes became standard for Chevy, my moms 2000 2500 had drums.
Old Mar 13, 2010 | 6:03 PM
  #17
dont they have 14 bolt six lug? why would i have to run two different sets of wheels? sizes? im running 15 inch rim right now.
Old Mar 13, 2010 | 6:06 PM
  #18
If you were to find a semi floating 14bolt, that would be 6lug, I always forget that all 1500s are 6lug now. the 14bolt full floater is 8-lug. Herres a few codes for ya for the rearend.
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 -- AXLE REAR, 4.56 RATIO
Old Mar 13, 2010 | 6:39 PM
  #19
i looked in the glove box and all i see is a sticker deal with a ton of numbers.
Old Mar 13, 2010 | 6:44 PM
  #20
Somwhere on that sticker is the code for your rearend. Try to take a pic of it and post it,
