rear end problem?
Old Jan 20, 2010 | 3:45 PM
country_09's Avatar
Default rear end problem?
Every time come to a complete stop something in my rear end feels like it is shifting...I don't know exactly what it is but i've talked to my friends dad's who owns a shop and he said it was the rear end. But my uncle who works on cars and trucks all the time said it sounded like it was my wheel bearings..any help would be appreciated!
Old Jan 20, 2010 | 8:29 PM
do you hear any sound or is it strictly a movement feel?
many of the GM trucks and Tahoe's get a clanking sound when the spline shaft into the tranny gets dry....
you will hear it when you come to a full stop and when you let off the brakes after the full stop almost feels like someone bumps into you...
Old Jan 21, 2010 | 2:10 PM
country_09's Avatar
that's about how it feels, like someone just rear ended me. even when i take off from a stop it seems to lug for a second then make that noise and start going like normal
Old Jan 21, 2010 | 3:53 PM
there is a special lube that is applied to the spline shaft the portion that goes into the tail stock of the transmission. Yes it is bathed in trans fluid but the fluid is not lubricating in this since.
You can have most tranny shops do it or get the lube yourself and drop the shaft and put the lube on...
IMPORTANT: you can not use just any kind of lube as it does mix with the transmission fluid and that is a hydraulic fluid, so a special lubricate that is compatible has to be used.
hotrodz71
Dec 2, 2012 6:37 PM
jensonb3
Mar 26, 2012 4:02 PM
TASpinney9110
Mar 15, 2011 5:54 PM
hydrodriver
Astro
Dec 11, 2010 8:52 AM
newcster68
Jan 17, 2007 6:55 PM
