Rear End for Pulling
Old Sep 14, 2008 | 3:40 PM
CrewCabFan's Avatar
Default Rear End for Pulling
On the 08s what are the best rear end for towing?
Old Sep 15, 2008 | 9:08 AM
chadt256's Avatar
Default RE: Rear End for Pulling
depends on what you have. if its a diesel the 3:73 is going to be best for gas mileage & pulling.
If its a 6.0 2500hd 4:10s
if its 5.3 1500 i wouldnt do it but if your pulling alot. 4:10s
Old Sep 15, 2008 | 2:58 PM
CrewCabFan's Avatar
I was looking for the rearends that come standard on the truck, sorry. This is also a 5.3L.
Old Sep 15, 2008 | 3:37 PM
bad2006z71's Avatar
depends on what you are pulling and how often. 3.73's area good all around gear. if you want a little more grunt and dont mind running higher rpm's on the highway then go 4.10's stay away from 3.42 at all cost
Old Sep 15, 2008 | 3:52 PM
CrewCabFan's Avatar
What's so bad abou the 3.42, I think this is the one I have, am I screwed?
Old Sep 15, 2008 | 5:34 PM
bad2006z71's Avatar
no youll be ok, its just not a great towing/power gear. its great for highway driving. my 06 w/5.3 and 3.42's would tach like 1800rpms at 75mph. for towing, 3.73 and 4.10 just allows the engine to not work as hard. use the tow/haul button when towing heavier loads and if you dont have a transmission cooler (ie the factory tow package) then that would be a good ad on.
Old Sep 15, 2008 | 8:21 PM
x1cn18's Avatar
i have a 2000 model with a 5.3 and a 3.42 and i pull alot and it does fine but the 3.73 would definatly help it get rolling better
Old Sep 16, 2008 | 8:12 AM
CrewCabFan's Avatar
I have the factory tow package, and what I will be hauling will not real heavy.
Old Sep 16, 2008 | 10:23 PM
x1cn18's Avatar
define not real heavy
NoBlueScreen
Uplander
Dec 19, 2011 4:52 PM
ClintM
Sonic (Aveo)
Jun 20, 2011 11:51 AM
TASpinney9110
Mar 15, 2011 5:54 PM
hydrodriver
Astro
Dec 11, 2010 8:52 AM
usmc2037
Dec 13, 2006 1:28 AM
