Rear Wheel Play
Old Oct 2, 2010 | 12:59 PM
blltrdr's Avatar
Default Rear Wheel Play
Last week I had my rear rear rotors turned and installed new pads on my 2001 Silverado 1500 LS 2WD Ext Cab. When I re-installed the wheels I notice that they both had a little in/out play in them. The LS had minimal but the RS had at least an eighth inch or more. Has anyone experienced this? Is this normal for this vehicle or is there something wrong? This truck also has the tow package with the locker rear end if that makes any difference.
Old Oct 2, 2010 | 1:14 PM
2wd-K5's Avatar
it comes with wear, u dont have much to worry about though. the rear inner axles are held with c-clips, they are known to fall out on very high milage trucks, but u have disk brakes, so u dont have anything to worry about
Old Oct 2, 2010 | 1:43 PM
blltrdr's Avatar
Well thanks for the answer 2wd-K5, still doesn't seem right to me but it has probably been like this for a while since this is the first time since I bought the truck that I had done any maintenance on the rear. I wasn't sure if it was supposed to be tight with no play at all or a little play as set up from the factory.
Old Oct 2, 2010 | 4:09 PM
2wd-K5's Avatar
be concerned if it is much more than an 1/8 inch
Old Oct 2, 2010 | 4:13 PM
blltrdr's Avatar
What would cause the excessive play?
Old Oct 2, 2010 | 4:46 PM
Overtime's Avatar
You will always have a little end play, it came new that way. Trucks a far from a swiss watch, I think you are just paying more attention then most people if you noticed it.
Old Oct 2, 2010 | 6:18 PM
2wd-K5's Avatar
very worn c-clips, but this usually only happens at around 300k
CPUFed
Jan 9, 2024 7:16 AM
trucker9
Dec 10, 2013 2:53 PM
Rmbb
Jul 31, 2012 11:28 AM
SmittyNBama
Jun 18, 2011 11:25 PM
lakeside_cruise
Astro
Jul 16, 2008 6:44 AM
