replaced cam,crank sensors. no start?
Old Jan 26, 2012 | 5:42 PM
vinman46's Avatar
Default replaced cam,crank sensors. no start?
I have a 1996 K1500 with 5.7 that won't start. I replaced plugs,wires,cap,and rotor 30k ago. Wife took the truck to Chevy dealer and they pulled a P1345 code. So i replaced the cam sensor, still will not start. Tonight i replaced the crank sensor, still no start.
I have spark and its getting fuel cause i can smell it and when i pulled a few plugs they are wet. It tries to fire when i crank it over,but wont run.
I`m at a loss. Any help would be greatly appreciated.
Old Jan 26, 2012 | 7:04 PM
EinST's Avatar
Welcome to the forum. Another member just went through a similar problem. Do a search for P1345. It means the CMP sensor is too far off from CKP sensor. The distributor is not installed correctly (off by a teeth?), it's turned too far away from the base, or distributor gear or timing chain is worn.
Old Jan 26, 2012 | 8:15 PM
MDTAHOE's Avatar
Professional Mechanic
In order to get a p1345 either the distributor was moved or the gear on the distributor is worn out. You must have a scanner to see the actual correlation. So it was towed to the dealer to pull the codes and then towed back home?
Old Jan 27, 2012 | 6:44 AM
shamrock246's Avatar
you can check the basic timing by putting the #1 cylinder a top center on the compression stroke and see if the rotor lines up with the #8 embossed on the distributor under the cap on a small pointer,the rest has do be done with a scanner or the dealer
travismm
Feb 25, 2014 4:09 AM
dpen
May 22, 2013 9:46 PM
TCsix
Aug 19, 2010 9:12 PM
maxxman04
Feb 3, 2010 10:56 AM
mschanha
Dec 12, 2007 4:48 PM
