Service 4 wheel drive light is on
Old Jan 27, 2011 | 10:51 PM
CHEVYKIng's Avatar
Default Service 4 wheel drive light is on
my light is bliking and it seems that there is no power to the transfer case motor which is new or the front diff actuator which was swapped with a new one. my front drive shaft spins but my tires dont. i can also shift the trans case into 4 lo 4 hi but and it seems to gear down but still no tires spinning i also checked all the fuse that i new of and they were good. so if some one could please help it would be greatly appreciated this thing is drivn me nuts
Old Jan 29, 2011 | 4:11 PM
dungholio's Avatar
If the T-case is supplying power to the front drive shaft then its a problem with the actuator on the front diff. if you have already replaced it then check the wiring. could be a bent/corroded pin in a connector or a broken. my advice to you is just take it to gm service
Old Jul 15, 2011 | 9:13 PM
GM Fixer's Avatar
Take it to a GM dealer, The actuater needs to be programed to the truck.
Old Oct 6, 2012 | 7:38 AM
pegrizz's Avatar
Just had a wire replaced along with connector pins. My Silverado did the same thing.
Billy HC
Dec 10, 2018 1:59 AM
twoshoes
Aug 11, 2015 9:31 PM
TLW64
Avalanche
Oct 28, 2014 11:59 AM
Jaysonic
Mar 8, 2010 9:07 PM
whitcre
Aug 20, 2005 12:26 AM
