Notices
Service Engine Soon (SES) Light
Old June 6th, 2009, 10:47 PM
  #11
ROTM Coordinator
Mike Sigmond's Avatar
Originally Posted by BlkSilv01
Quick question. Is there any way to check the codes on my 2001 Silverado 1500 4x4 without a code reader? i know on some vehicles you can turn the key on a ceratin number of times and codes will appear.
Wait, the Service Engine Soon light usually means you have a critical problem, Did you mean the Check Engine Light? and is either of them even on? If not , you dont have any codes to read.
You didnt clearly say if it was on or not, just curious.
Old June 18th, 2009, 6:52 PM
  #12
BlkSilv01's Avatar
so here's the update. I bout a code reader from advance auto and it was the dreaded EVAP EMISSIONS code. gas cap was plenty tight. i took the plastic cover off of the top of the engine and seemed to me the purge valve was extra loose. i'm not sure if it is suppose to have some play in it or not but i took a couple lock washers and put over the bolt, tightened it back down and cleared the code. that was about a week ago and now the SES light has coem back on.
Old June 19th, 2009, 11:00 AM
  #13
IF you over fill your fuel tank i.e. don't stop at the first shut off and try to get that extra dollar of gas in , it possible that you have fuel in the evap system.
If you are able to remove any of the vacuum lines to the evap system and they have fuel (liquid) in them that is most likely the case.
Melody Smith Arquillo
December 3rd, 2012 12:48 PM
texasdontholdem
January 4th, 2011 2:26 AM
Toocim
January 2nd, 2010 9:48 PM
kimoZ71
December 12th, 2006 10:36 PM
hopkinstx
September 17th, 2006 12:29 AM
Quick Reply: Service Engine Soon (SES) Light
