Shift knob
Old Sep 9, 2006 | 1:55 PM
swhitney2003's Avatar
Default Shift ****
I have a 1998 K1500 manual transmission, and was wondering what size threads are used for the shift ****. I am looking into getting a T-Handle and wanted to make sure I got the right thing
Old Sep 9, 2006 | 2:29 PM
Nomad76lj's Avatar
Default RE: Shift ****
you will have to look at them. i think some come with a sleve you put over the threeds and hold the shift **** on with allen keys. hope this helps.
Old Sep 9, 2006 | 2:50 PM
I was looking at these hurst shifters...
http://www.jegs.com/webapp/wcs/store...tegoryId=10521
They have different threaded versions. I'm also curious as how to remove the stock shifter **** (I'm assuming it is threaded on one way or another). I have read somewhere about removing the gear map on top of the ****, or removing some "staple"... I'm not really sure. Any ideas?
Old Sep 9, 2006 | 11:50 PM
kcb37's Avatar
If you have a book look in that. If not look right under the **** if you have a nut loosen that and the **** will screw right off.
Old Sep 10, 2006 | 6:17 PM
There is no nut at the bottom. There is some white plastic piece underneath the material covering the **** (I cannot see much of this plastic piece because I have to stretch the covering out to see it. However, I see no threads, screws or nuts. It is just a smooth and cylindrical.) There has to be a feasible way of removing the **** without breaking it open.
DWheeling
Cobalt
Apr 3, 2008 8:26 AM
Russ66
Colorado
Jan 7, 2008 2:31 PM
Sasquach
Sonic (Aveo)
Mar 19, 2007 11:03 PM
ronjon13
Dec 22, 2006 7:18 AM
comhunter
Jan 25, 2006 8:58 PM
