shifter stuck in park
Old May 10, 2011 | 1:21 PM
papasmo2000's Avatar
Default shifter stuck in park
I have a 98 silverado 1500 and the shifter in stuck in park. I've heard there is a solenoid you can disable in the steering column. Anyone know how to do this....
Old May 10, 2011 | 1:34 PM
dock420's Avatar
Default 2 links that was found...
https://chevroletforum.com/forum/sil...ut-park-32022/
Chevrolet 1500 Pickup; wont shift out of park automobile forum
Looks like its not an uncommon problem.....
Good luck
Old Jun 23, 2011 | 7:52 PM
sgtsalt25's Avatar
Default Fix for won't go out of park
A couple of days ago I replaced my brake light switch. WHAT A PAIN! Everything was fine until my son called me from football practice and said the truck would not shift out of park. I figured it had to be something with the switch so I crawled back underneath and sure enough, the switch had slipped out to the end of the bar that runs through the center of the switch. When I bought the switch, I looked for a new clip kit but everyone was out or didn't carry them so I put the old one back on and it came off. I pushed the switch back in place as far as I could to the drivers side and got it home. I used a small tie wrap, looped it over the bar and pulled it as tight as I could. I don't know how long this will last but it should get me through until I can find a clip kit. So, bottom line, your switch my not be bad; it just may be that it slid out of place and the link rod on the side of the switch isn't lining up so the shifter won't budge.
johnmcgrady35
May 26, 2021 12:34 AM
BigblackHo3
Apr 5, 2013 8:54 AM
DoABurnout
Sep 3, 2011 6:04 PM
fredski53
Jul 21, 2008 11:45 AM
