Shudder or miss at cruising speed
Old Mar 4, 2011 | 9:49 PM
levi3's Avatar
Default Shudder or miss at cruising speed
I have a 1998 Chevy Z71 pickup with a 5.7. I recently had the Spider injection replaced. Since then I am noticing a shudder or miss at cruising speed that last for a second, no codes. Below are the things that has been done since the issue started.
IAC valve replaced
New wires and plugs.
The whole distributor replaced
What else should I check?
Thanks
Levi<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
__________________
2001 GMC Yukon
1998 Chevy Pickup Z71
1984 Chevy 3/4 pickup
2003 Mercury Marauder
1998 Chevy Lumina...
Old Mar 5, 2011 | 11:27 AM
loosebearing's Avatar
Does it have this symptom all the time? What was it doing before spider installed?
Maybe injector .
Old Mar 5, 2011 | 12:10 PM
levi3's Avatar
It was causing a miss fire on cyl 5. That miss fire is gone. The new problem does not happen all the time but in a 25 mile stretch it will occur 3 times.
Thanks,
Levi
Old Mar 5, 2011 | 1:08 PM
Getting no codes .. hard to diagnose. Could be spark or fuel related.
Have you changed anything plugs .. Anything related to spark.
Check fuel pressure 60 to 65 psi. and hold steady. Run some good injector cleaner through it.
Old Mar 5, 2011 | 7:07 PM
levi3's Avatar
I know it sucks with no codes. I tried all that and had no luck.
Thanks,
jrhope
Oct 14, 2023 4:02 PM
Schveb
Sep 18, 2017 9:05 PM
levi3
Mar 4, 2011 9:45 PM
Overnite
Astro
13
Nov 9, 2010 6:48 AM
