speedometer stuck
Old Oct 19, 2006 | 11:45 PM
icedawgs's Avatar
Default speedometer stuck
Any ideas on a speedometer that is stuck? It will show between 75 to the bottom of 110 at all times, even when shut off, and/or over night.
Old Oct 25, 2006 | 2:57 AM
HP15's Avatar
Default RE: speedometer stuck
Suburbans have the same problem eventaully it will go out all together
Old Dec 4, 2006 | 12:13 PM
skoot61's Avatar
My spedometer is the same as yours... the only good thing is when you get stopped for speeding you can say you really didn't realize it and be able to show them you are doing 110mph .....stopped. Dealer quotes me $800.00 to repair. I'm just going to take my chances.... Skoot61
Old Mar 4, 2007 | 3:46 PM
Amdel's Avatar
The problem is the small stepper motors in the instrument cluster that move all of the needles (Speedo, tach, gas, temp, etc.). If GM won't fix it for free, and you've exhausted all other avenues, you have some options without paying GM several hundreds of $. If you're handy with a soldering iron, you can fix the speedo for about $12, and the whole cluster for about $75, or you can have someone repair it all for you for about $150. The problem is the same withseveral 2003 to 2007 GM vehicles: most trucks andSUVs, and somecars. See my post in another forum for more details: http://www.topix.net/forum/autos/chevrolet-silverado-1500/TR5QAB2MN19BL1D2J/p8
Old Mar 5, 2007 | 11:12 PM
rrjorg's Avatar
I've got a similar problem with my 01 gas gauge. Do anyone know if this problem goes back that far? My niece has a Yukon doing the exact same thing. Same year, same engine.
Anyone?
Thanks!
Old Mar 12, 2007 | 4:48 AM
VAhorseman's Avatar
My 04 silverado done the same thing. Thankfully it started working again. I believe the stepper motor would be the place to start and while you've got the instrument cluster out you should replace all of them.My buddy has an 01 HD his tach stays pegged at 6 grand.
kevin2003trailblazer
Feb 18, 2015 6:52 PM
jbsorensen
Nov 30, 2010 12:57 PM
BatteryMan
Oct 8, 2007 12:20 PM
dcshan
Jul 25, 2007 7:39 AM
