Starting problem k1500
Old Oct 27, 2013 | 10:13 AM
ChevyJo's Avatar
Default Starting problem k1500
Hello,
We have bought yesterday a silverado stepside k1500. When we drove home and went to the gasstation. When we restarted the enginge, the only thing we heard was the clicking of the solenoid and the gage of the battery meter went down to 9 volt when I turned the key. We went to a shop and asked for a starter battery, and then fired up the chevy. This morning it started like 5 times. Then this afternoon we decided to do a little trip, we stopped somewhere for 5 minutes. When we wanted to start up again... again the same thing, clicking of the solenoid but no starting engine. I mesured the battery, 12,6 v. Alternator 13,56 v... It's like something discharges the battery when we drive... or the chevy won't start when it's hot ?
Old Oct 28, 2013 | 10:25 AM
Fishinfooleric10@aol.com's Avatar
Im thinking a bad ground that is wearing out your battery. I would start there first and check all your ground connections.
Old Oct 28, 2013 | 12:12 PM
Are you still using the original battery? If so you need to do a load test on the battery.
Old Oct 31, 2013 | 1:58 PM
Official GM Rep
ChevyJo,
If you need to have your Chevrolet dealership look into this please let me know.
Erica Tiffany
Chevrolet Customer Care
Old Nov 1, 2013 | 11:57 AM
ChevyJo's Avatar
Check all ground connections? Check the resistance between each ground point? Which are the most important?
Old Nov 1, 2013 | 12:02 PM
ChevyJo's Avatar
No it's not the original battery. It's a Yuasa from 2008. What is the original battery or maybe a better one then the original?
When I turn the contact on, the voltage of the battery drops to 11,99 volt. When the contact is on, it consumes plus 3 amperes.
How can I do a load test?
thx
Old Nov 2, 2013 | 11:19 AM
Take the battery to Autozone or Advance, they will check it for free.
Old Nov 3, 2013 | 2:35 PM
Polydorus's Avatar
Where are you located ChevyJo?
Old Nov 4, 2013 | 10:58 AM
ChevyJo's Avatar
I did a load test, hung a multi meter on the fully loaded battery, started the engine and the multimeter went down to 2,27 volts !!!
So replaced a new large battery, 100 Ah and 647 cca. It starts fine for now.
I am from belgium
Old Nov 4, 2013 | 1:54 PM
Polydorus's Avatar
Smile
Good. You would probably would have found out very quickly that the battery was failing once winter set in.
joshm
16
Feb 9, 2015 12:07 PM
2keybird
Dec 31, 2014 9:20 PM
tom5170
Oct 9, 2014 12:39 PM
JayDm
Feb 19, 2014 2:16 PM
