Steering gear
Old Nov 27, 2013 | 7:26 PM
talltaylor's Avatar
Default Steering gear
Hi guys newbie here. I have a 05 Silverado. Lately just out of no where it is hard to turn. Doesn't matter if its cold or hot. I suspect the steering. I had an 01 that did the same thing unfortunately I totaled it before I had a chance to fix it. Any thoughts?
Old Nov 27, 2013 | 10:19 PM
remove the belt and check for a broken power steering pump shaft. if its broken the pulley and shaft will pull out of the pump.
Old Nov 28, 2013 | 7:19 PM
talltaylor's Avatar
I meant to say steering gear. I don't think its the pump because when it was happening on my other truck I changed the pup and it didn't make any difference. I have an extended warranty on the truck that is good for a while but I would like to figure this out.
Old Nov 28, 2013 | 7:51 PM
put a steering gear in it then, if your wrong you only be out about 600$.
only a shop will have the proper equipment to test this. its either a pump, gear or line restriction.
Old Jul 30, 2014 | 12:19 PM
ToTo's Avatar
I just bought a 09 Silverado 4X4 WT. Nice truck with 68K on it. It has rack and pinion and steers badly. It is stiff and because of that I am always over correcting. It doesn't steer any differently at random speeds. I had it greased but it only has 2 grease fittings. One on each tie rod. None on the ball joints like my 99 Silverado has. The 99 has a "power box" instead of rack and pinion. At 265k it is a much easier to drive. The 09 tires me out and is a safety issue. I took it to the dealer I bought it from and they drove it and said it was the same as all other silverados. I have driven other ones like mine and they do steer easier. This acts as thou something is dry or it doesn't have enough power assist. Thanks..Arnie
Old Jul 31, 2014 | 8:49 AM
Official GM Rep
Hi Arnie,
So sorry to hear this! We would be happy to reach out to your dealership to work with them on a resolution. Send us a private message at any time with your name, address, phone number, VIN, mileage, and name of involved dealership so we may help.
Jessica
Chevrolet Customer Care
r3333d
Jul 24, 2014 9:16 AM
97Silverado1500
Nov 7, 2012 3:50 PM
73shark
Nov 21, 2007 4:00 PM
mrjonesnsa
Jun 17, 2007 6:37 PM
313hitman
Nov 1, 2006 2:35 PM
