Stock Spacers
Old Nov 22, 2011 | 9:58 PM
GreatWhiteLT's Avatar
Default Stock Spacers
I just removed the rear spacers from leaf springs. It dropped it about an in. in the rear and now the truck sits basically level. Is there any advantage to the spacers or are they mainly there too keep the rear end off the ground when I tow or have my truck loaded down? Thanks in advance
Old Nov 23, 2011 | 11:35 AM
slw210's Avatar
What spacer are you referring? What truck do you have?
Old Nov 23, 2011 | 6:00 PM
country_09's Avatar
You mean the block? It's just there do when you tow, your front end isn't sky high and it'll sit level when you tow somethin. Or if you were goin to lift it, they give you a bigger one to raise up the rear end
Old Dec 2, 2011 | 7:22 PM
it's the rear block, i didn't think it had any performance reason so i shipped it. Looks way better now. Noticeable diff
Old Dec 5, 2011 | 2:58 PM
slw210's Avatar
Was it wedge shaped? If so it provided the proper angle for the pinion to the driveshaft.
Old Sep 23, 2012 | 10:48 AM
tmyers's Avatar
New User
Awaiting E-mail Confirmation
I have a 07 crew cab (new body) that the rear end sits up higher. I don't like it because it's my daily driver, not a work truck. I have been thinking about removing the spacers under the leaf springs. I am talking about the ones between the axle and the leaf spring, leaving the cradle for the leaf spring to sit down on the axle. I don't see how it would affect anything but the height of the body. Of coarse I may have to replace the U bolts if there is not enough treads to tighten it up. Can anyone give me any thoughts or let me know if this will affect the ride. THANKS tmyers
Kniy93
Feb 8, 2014 8:45 PM
thommcbr1
Mar 18, 2008 1:04 PM
thdrill
Nov 2, 2007 11:17 AM
GMz71
Oct 11, 2007 10:26 AM
