Surprising my husband with a chevy HELP!!!
#32
Coolant Leak
I noticed a leak on the front driverside so I checked the upper radiator hose, bent it and it started pouring out. So I changed the hose. Helped a lot! But... I let it sit over night and it is very very slowly leaking coolant still. There was a very small wet spot on the ground same area. Why is it still leaking? I re checked the hose clamp and the hose it on there really good. New clamps, what's wrong?
#34
i hope so. My husband will be home in 2 weeks and i want everything perfect! I just changed the belt and a rusted pulley when i did the hose. Do you have any ideas of why my Air Bag light is on? I was reading when starting it up, it will flash 7 times, then if it stays on there is a problem. I checked the fuse, what else simple things can i do?
#35
Are you sure that the radiator is leaking from that top hose. I know mine had a leak in it in the line below the top line. So i just replaced the radiator
#39
Perfect is a state of mind, chevywife. I spent 4 years in the Navy with sporadic leave.
I think I can state with some degree of certainty that your husband will be moved.
When your husband gets back, and you're waiting for him, with that rippin' truck all fixed up, I think he'll consider the situation perfect, even if the truck did need a little work here or there.
luni1974
April 29th, 2014 2:31 PM
