Synthetic oil for a Duramax????
Old Jan 27, 2007 | 2:00 AM
art's Avatar
art
Default Synthetic oil for a Duramax????
I have a Duramax with the Allison and the book says to use 15-40 oil rated for a diesel. I noticed Rotella has a 5-40 synthetic oil rated for diesels and was wondering if this would be OK for my Duramax? The label on the oil bottle said it's good for Duramax, Powerstroke, Cummins and others. Does anybody know how using this oil might affect the warranty? Is this a good oil to use in the Duramax? What's the best oil filter to use?
Thanks in advance for your help........
Old Jan 27, 2007 | 10:21 AM
Waboom!!'s Avatar
Banned
Default RE: Synthetic oil for a Duramax????
Using the brand that you want to wont't affect the warranty unless it didn't have the correct rating code which basically all modern oils do. besides what are they going to do, send it out for analysis?
Old Feb 2, 2007 | 11:46 PM
art's Avatar
art
If somebody had a better answer than the one above I would appreciate it. What I'm wanting to know, will the the 5-40 Synthetic oil damage the Duramax and if not, is it worth the extra money?
Old Feb 3, 2007 | 12:11 AM
Waboom!!'s Avatar
Banned
buddy.. does the 5- 40 carry the proper rating???
Old Feb 3, 2007 | 12:40 AM
art's Avatar
art
I'm not your buddy dumb ***, I don't need your sarcastic answers. Go pester somebody else........
Old Feb 3, 2007 | 12:56 AM
Waboom!!'s Avatar
Banned
If I were you I would run about a quart of bleach in the crankcase.On the freeway of course, while cold.
Old Feb 11, 2007 | 7:52 PM
jshultz's Avatar
Art,
If your looking for a good quality synthetic oil. Why not check out amsoil.com. You can use their 15w40 Heavy Duty Diesel oil which will allow you to drive 25,000 miles without changing the oil and the filter will last the same duration.
Their have been customers who have driven up to 80,000 miles before changing the oil using oil analysis. If you would like more information regarding this fine product, you can email me at osh599@yahoo.com.
I have several satisfied customers including a fire department that has been using Amsoil for over a year with outstanding results. This fire department also put Amsoil's synthetic transmission fluid in their Impala's to which is good for 60,000 miles under severe conditions.
This oil will increase your gas mileage and also save you time by not having to change it every 3000 miles. Did you know that most other synthetic oils still recommend the 3000 mile interval? Sad but true.
Jim Shultz
Independant Amsoil Dealer
ZO#: 2001353
Old Feb 11, 2007 | 10:52 PM
shnormo's Avatar
https://www.amsoil.com/storefront/Se...?CategoryID=18
We're all hungry here and good for the self promotion, but sometimes it's still cheaper to get it from the source. NO OFFENSE!
By the way, we stopped carrying Amsoil at our shop because their "extended" drain intervals don't match up with the factory recomendations. If your vehicle is under warrenty and you go over the recomended drain interval and you have issues, the dealer won't honor the warrenty. We haven't had a problem, so we don't know if Amsoil will cover the repairs either. They DO have good products and I strongly recomend using it in your desiel.
Old Sep 29, 2020 | 3:41 PM
Kirito's Avatar
Please tell me which oil for duramax is better to choose if the car is already 2008?
Old Sep 30, 2020 | 7:53 AM
Stiller's Avatar
In fact, if the car is already with high mileage, it is necessary to think over to pick up the best option just for oil. I already know by myself that approximately need and can choose here. For example, I now take Shell Rotella T6 5W-40 Full Synthetic Heavy Duty Engine Oil, but here you can already see for yourself, there are several options that you can consider, or rather read about the recommended oil for duramax, oil for duramax lml here the best quality, already look purely on the basis of local characteristics and their own preferences, there are described the pros and cons of this or that oil. I'll take the one that I pointed out stably, because if you can take a special look at it =).
bananas
Oct 24, 2022 2:24 AM
Vern31
May 7, 2018 1:26 PM
Tfriend
Jul 31, 2013 7:18 AM
Big bird
Oct 21, 2012 7:51 PM
melat70
18
Mar 12, 2010 11:25 AM
