Old Aug 10, 2015, 7:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
tailgate stuck closed
Old Nov 7, 2010 | 11:32 AM
Burnett 1500's Avatar
Default tailgate stuck closed
on my 03 1500, i try to open the tailgate, and it wont come down. but when i push on it (to close it normally) it latches again. i need to fix that to get to the rear lights. i need to change a bulb.
any suggestions?
thanks
Cory Burnett
Old Nov 7, 2010 | 2:21 PM
gotstylez's Avatar
so you cant get it unlatched?? or you can get it unlatched it just dont move..are both sides unlatching??? i'd say one of the little plactic pieces of the rods that make come unlatched broke...
Old Nov 7, 2010 | 6:25 PM
I can get one side unlatched. I looked at it, the side that doesn't unlatch the rod has broken off.
Old Nov 8, 2010 | 10:43 AM
ericnottelin's Avatar
Try unbolting the bolts on the rear of the tailgate. You then can pull out the latch mechanism. From there, you should be able to manually open each latching mechanism.
Hope this helps
Eric
Old Nov 8, 2010 | 6:23 PM
kawik1500's Avatar
if it pulled off at the handle in the tailgate, you should be able to pull the plastinc around the handle out and manually pull the rod to open the tailgate....
Old Nov 9, 2010 | 6:49 PM
s34n's Avatar
x2 with kawi and stylez. my friend slammed the tailgate on my 04 1500 and broke one of the plastic pieces that hold the rod to the handle so only one side was unlatching. you can take off the bezel trim piece and see the latch assembly. good luck
Old Nov 22, 2010 | 11:44 AM
silverado13's Avatar
thats probably the most common problem with any silverado ever, they need to redesign the lock mechanism
Old Apr 30, 2015 | 11:37 AM
floyd_alwine's Avatar
Default 1988 suburban tail gate stuck
I just got this suburban and i can't get the tailgate to move.how can I get to drop ? It's in pretty ruff shape
Old Apr 30, 2015 | 3:41 PM
They need to go back to using metal clips instead of plastic just like they used to in the old days.
Mbell
Aug 1, 2012 2:34 PM
choffy21
Apr 2, 2011 4:04 PM
99monguse
Jan 31, 2011 10:39 AM
97astrovanner
Astro
Jul 22, 2009 12:49 AM
mrb2222
Aug 22, 2006 12:55 AM
