tailgate wont open 99 silverado - help?
Old Jan 6, 2007 | 2:21 PM
hayseed's Avatar
Default tailgate wont open 99 silverado - help?
my tailgate wont open on my 99 2500,, the handle seems to release the gate but its still being held by the latches in the upper corners -- is there a way to release this ? -- the handle appears to be riveted on - should i drill this out or is there another way to resolve -- i can see some of the mechanism when i look underneath the handle but i am not sure how the assembly works -- help please
Old Jan 8, 2007 | 11:45 AM
lost_in_alabama's Avatar
Default RE: tailgate wont open 99 silverado - help?
There should be a bolt on the inside of the tailgate that will allow you to remove the latch mechanism and find the problem.
Old Jan 8, 2007 | 8:07 PM
tireguy05's Avatar
i have the same problem on my 99' 1500. I removed the black casing around the latch. then you can release the latch manuelly. The only problem for me is finding why the rod can't stay in the latch.
Old Jan 8, 2007 | 10:58 PM
carlsndfw's Avatar
I had the same problem. Remove the cover on the latch. Probably the pin that holds the rod is broken. Good luck finding one except at Chevrolet $$$$$$
Tootallmech
Aug 7, 2023 11:49 AM
scarbo68
Nov 3, 2011 4:54 PM
98ch3vy
Nov 22, 2008 9:05 AM
Growl60
Oct 27, 2008 11:23 AM
groundupkustoms
Jan 22, 2008 11:00 PM
