Temperature gauge pegged high
Old May 25, 2021 | 7:36 PM
  #21
kevinkpk's Avatar
Originally Posted by kfrost1
The sending unit was broken off flush were the plastic goes into the housing
Is it possible he pin connection could be shorted to each other (visual inspection)? Check continuity from the pin to pin, should be infinity.
Old May 25, 2021 | 8:08 PM
  #22
kfrost1's Avatar
It’s a single wire and I replaced the connector.
I thought that I may not be getting a good ground so I clamped a 6AWG wire to the outer casing to a good ground and it still pegged out.
with the ignition on, the gauge goes to around 230. Start it and it immediately pegs out
Old May 25, 2021 | 8:33 PM
  #23
kevinkpk's Avatar
So, is,was this a single green wire from the sending unit front driver side to the dash gauge? Is the temp gauge you are refferincing to low left on the dash?
Old May 25, 2021 | 9:18 PM
  #24
kfrost1's Avatar
Yes it was a single green wire on the left side (drivers side). The temperature gauge is bottom right on the dash
Old May 26, 2021 | 8:55 AM
  #25
kevinkpk's Avatar
https://www.americanautowire.com/vie...oubleshooting/
Old May 27, 2021 | 11:31 AM
  #26
kfrost1's Avatar
Does anyone know what the resistance should be at the connector?
Old May 27, 2021 | 3:03 PM
  #27
kevinkpk's Avatar
Going out on a limb, I think the wire should be battery voltage to the sending unit. I believe the way it works as the temperature rises, it increases the resistance, drops the voltage to the gauge, and that should correspond to temperature.
Old May 27, 2021 | 3:06 PM
  #28
kevinkpk's Avatar
I could be backwards, if you have the sending unit out, check resistance cold, then put it in hot water, check the resistance, it could be as it heats up the resistance drops.
Old May 28, 2021 | 7:43 PM
  #29
kfrost1's Avatar
Finally fixed the problem!
after connecting a 150 ohm resistor to verify the gauge should read 210 - 220 degrees ( which it did) that proved that the connector to and including the gauge works as it should, I bought a 3rd sending unit and it’s reading correct. Verified it with an infrared thermometer.
Thanks for the help everyone!
Old May 29, 2021 | 7:08 AM
  #30
kevinkpk's Avatar
Glad it's fixed. I know well the frustration of a "new" part that isn't any good.
