Temperature gauge pegged high
Old May 23, 2021 | 11:51 AM
kfrost1's Avatar
Default Temperature gauge pegged high
I have a 95 Silverado 1500, 5.7. I replaced the sending unit twice, thinking the first one was bad. With the sending unit out of the vehicle and plugged in, it reads 100 deg. place the sending unit against the block and it pegs out at 260. Could someone please help me figure out what the problem is?
Old May 23, 2021 | 11:57 AM
Make sure you have the correct sending unit for your engine.
Old May 23, 2021 | 11:59 AM
kfrost1's Avatar
I made sure that I got the correct sending unit the 2nd time. same problem.
Old May 23, 2021 | 12:34 PM
kevinkpk's Avatar
Try installing it with thread sealant.
Old May 23, 2021 | 12:46 PM
kfrost1's Avatar
I used Teflon tape. should I use something else?
Old May 23, 2021 | 1:26 PM
kevinkpk's Avatar
You didn't post that you installed it, but held it against the block. Teflon is fine. Do you have an ohmeter? If so, check the pins none installed for what resistance it has, then re-install it. It shouldn't change, but either it is, and that is causing your issue, or you need to look at the gauge. As you pointed out this is the correct sending unit, these are matched to the gauge.
Old May 23, 2021 | 3:57 PM
kfrost1's Avatar
I measured it uninstalled and it read 1.86k. I installed it and it read 1.36k
Old May 23, 2021 | 4:17 PM
kevinkpk's Avatar
At this point, can you see if you have a chaffed wire from the sending unit back to dash?
Old May 23, 2021 | 4:58 PM
kfrost1's Avatar
I followed the wire back to the firewall and it appear to be good
Old May 23, 2021 | 5:16 PM
kevinkpk's Avatar
Does the gauge automatically read high when you turn the ignition switch to on?
