th350 to 700r4 swap questions
Old Jan 19, 2014 | 10:14 AM
chevykid53's Avatar
Default th350 to 700r4 swap questions
So i recently picked up a 91 chevy pick up and one of the previous owners had put a th350 transmission in it and i just picked up a good 700r4 that i want to swap back into the truck. So i was wondering what kind of modifications i would have to do like with the driveshaft and output shaft on the tranny. Would i be able to use the same transfer case or do i need to get a different one? And i was also wondering if i could use the same torque converter or if i would have to get another one. Any help is appreciated. Thanks in advance.
Old Jan 19, 2014 | 11:20 AM
Allan In NE's Avatar
Different converter and TV cable assembly.
If he did it right, you should only have to change the cross-member to the rear set of holes in the frame. Electrical connection should still be there, I'd think.
Old Jan 19, 2014 | 11:54 AM
chevykid53's Avatar
Ok i can get a converter from the guy i bought the transmission from for like $20 so im good there but i wont have to shorten the driveshaft or change the output shaft in the transmission at all? And is the tv cable the cable on the tranny that makes it go into od? Thanks
blacksn
Apr 9, 2014 6:01 PM
Ironhead Dave
Chevelle & El Camino
Dec 5, 2010 4:34 PM
sniperx7
Sep 28, 2009 4:10 PM
sulichal
Apr 8, 2008 3:39 AM
An89Chevy
May 13, 2007 7:06 PM
