tranny question
Question for all you guys, My 2000 extended cab 5.3 automatic has started stickin in 2nd gear when i stop every once and a while when i take off i can feel it drop back to firstbut only if i kind of take off fast if i take off easy it stays in 2nd
looks good , not burnt full dont know if it has ever been serviced though havent had the truck that long and it has 90000 on it now and kind of scared to do it now
dont be afraid to service it if its at 90000 and not burnt smelling. just change the atf. i felt the same way at 90000 for my 98 2 months ago so i just said screw it im doing it before anything happens. changed the gasket filter like im supposed to. found out it was done before and the person used gasket maker with the gasket and some of the sealer got into the filter luckily not into the system. i took apart the filter and found small small specs of the gasket and fabric from when it was serviced. i used a magnifying glass so thats a perspective of how small things were. but in any case, i work at jiffy lube and so i just did my truck myself and everything looks good. just do it. if you feel the need, use some lucas transmission friction modifier. my friend used it when he said he was getting a lot of slippage and it fixed it. it was on an olds aurora 2001 with over 100000 miles. he said it shifts nicely no sticking or anything. but my opinion, do the flush. you need to. when you get it done, ask to see the trans pan and the magnet inside so you can see all the metal shavings from your trans. dont worry thats exactly what it does. its friction. thats why theres a magnet to catch it.
something else to add it used to do this all the time with my old programmer thought thats what it was so i got a new one it quit now it has started doing this only noticed it the past few days been cold though could be a factor
A. T
November 29th, 2011 5:03 PM
DeHartShadow
March 28th, 2010 10:10 PM
89silverado283
February 16th, 2010 8:50 AM
revamped
August 24th, 2008 10:48 PM
revamped
January 23rd, 2008 4:03 PM
