tranny swap
Old May 18, 2010 | 10:58 AM
theheartman's Avatar
Default tranny swap
Can I put a 70's 350 turbo in my 95 C1500
Old May 18, 2010 | 11:30 AM
maxxman04's Avatar
first, welcome to our forum, glad ta have ya!!
yes, a t350 will go into the 95, BUT it's not a 100% straight swap. i believe the spline count on the tailshaft is different, but using the yoke with an adapter ujoint would solve that. also, the driveshaft might end up being a different length, probably gonna need to be a little longer, as the 350 is a little shorter than the 4l60e's. also, the speedometer on the 95 is electronic, where the 350 isn't, so you may run into no speedo. tranny mount may need to be relocated/modified as well. the t350 will bolt right to the motor tho.
Old May 18, 2010 | 9:48 PM
72c10gunn's Avatar
I think maxxmans got u covered, i just wanted to add that i believe ive seen an adapter that converts the old mechanical spedo to elec. right at the transmission where the spedo cable goes
cueman
Feb 6, 2012 9:37 PM
DeHartShadow
Mar 28, 2010 10:10 PM
89silverado283
Feb 16, 2010 8:50 AM
revamped
Aug 24, 2008 10:48 PM
revamped
Jan 23, 2008 4:03 PM
