Trans Slip or normal chevy
Old Feb 22, 2014 | 9:56 PM
popwar's Avatar
Default Trans Slip or normal chevy
Hi , I'm Dan . Ive had my Silverado about 2 weeks now . Love the truck , but concerned if my trans is slipping from 2nd to 3rd? I've read similar threads , but figured I would make one with a video to see peoples input . Fluid is clean . Sometimes it may not do it depending on how you accelerate . Heres a video of it. My dad has been a gm guy all his life and has rebuilt many gm trans . He says almost every chevy hes driven does it and to not worry about it , but I have my doubts . Turn the volume up to hear it more clearly .
<iframe src="//www.youtube.com/embed/nsidEDZGbHs" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
Old Feb 22, 2014 | 10:19 PM
sledge.impy's Avatar
What year?
That does look peculiar.
Old Feb 22, 2014 | 11:38 PM
popwar's Avatar
03 , 5.3 motor , 104k miles
Old Feb 23, 2014 | 5:11 AM
Allan In NE's Avatar
The shift between 2 and 3 is a "timed" shift. That is to say, one component has to be released and another applied rather than with the other shifts which are "stacked" one upon another.
When you see this "flare", it is "almost always" due to a small momentary hydraulic leak.
Allan
Old Feb 23, 2014 | 7:49 AM
popwar's Avatar
So it is just normal operation? Would I benefit from the gm pcm update? I read its suppose to improve shift points and shifting in general .
Old Feb 23, 2014 | 8:12 AM
No, it's not 'normal'. Are you talking a re-flash?
Allan
Old Feb 23, 2014 | 9:02 AM
popwar's Avatar
Yes . there's a tsb I seen with that reflash update addresses the trans flare issue on some chevys
Old Feb 23, 2014 | 9:19 AM
Yes, of course. That is always the first step to take and will "probably' cure your ills.
Old Feb 23, 2014 | 9:44 AM
popwar's Avatar
Ok , Will post back probably monday to let you know if it fixed it . Thanks for your input
Old Feb 25, 2014 | 9:59 AM
popwar's Avatar
It still does it but doesn't hang as long before 3rd gear
