Transfer case leaking!
Old Oct 19, 2013 | 6:49 AM
white03's Avatar
Default Transfer case leaking!
Just went through all my fluids and when i took the drain plug out of the transfer case there wasnt much in there. I refilled it and drove a short distance and noticed it leaking! It looks like theres two little pin holes which one looks like already been jb welded! What caused this and how do fix it?
Old Oct 19, 2013 | 7:04 AM
Allan In NE's Avatar
Caused by the oil pump housing rubbing against the case housing. Has to be repaired from the inside.
Allan
Old Oct 20, 2013 | 12:51 PM
scoutski's Avatar
The "pump rub" problem has been around for some time now. Merchant Automotive sells a pump housing that is much thicker and it won't eat a hole in the case. I did mine about 10 years ago and have not had a problem.
Old Oct 21, 2013 | 5:50 AM
white03's Avatar
Does it rub the case in 2 wheel drive? Or 4 wheel? Or both?
Old Oct 21, 2013 | 6:27 AM
Anytime the output shaft is turning.
Allan
Old Oct 21, 2013 | 6:49 AM
scoutski's Avatar
White03 There is a complete DIY on the transfer case removal and pump kit install on the dieselplace.com site. You will find all the information you need.
Scoutski
Old Oct 21, 2013 | 8:49 AM
white03's Avatar
Thanks guys! About how long does it take to do this job?
Old Oct 21, 2013 | 2:29 PM
scoutski's Avatar
It should only take a couple hours unless you are an old fart like me. I spent about four hours on mine but then, I like to work slowly.
TahoeLTGuy01
Nov 2, 2014 12:24 PM
Chevy_Joe
Feb 26, 2012 2:22 PM
fsh4fun05
Aug 20, 2010 12:46 AM
89k5blazer
K5 Blazer
Oct 15, 2009 8:28 AM
fleetline51
Astro
Feb 21, 2008 7:38 PM
