Transmission Gear Selection
Old May 7, 2013 | 1:25 AM
TDSSD's Avatar
Default Transmission Gear Selection
I have a 2011 2500HD with the 6 Speed Auto. I have a camper on it and will be towing a Jeep Wrangler behind it. I would like to know when to use M 3,2,1 or am I ok in tow haul mode with lever in drive?
George
Old May 7, 2013 | 1:47 AM
Fishinfooleric10@aol.com's Avatar
Yeah just put it into tow haul mode and you are good to go. In tow haul mode the transmission ( I pretty sure) locks the clutches in so that don't have play in them. With a load and play in the clutches like regular driving, it will cause a lot of heat. Thats why you shift at higher rpms ( to not strain trans) and firmer shifts and if you let off and coast then press accelerator again the transmission will "grab" at higher rpms to keep you moving. I would not manually shift when you have a load, just put it into tow haul mode and you will be fine, that is what they designed it for. I hope this puts your mind at ease about how to tow your stuff.
Old May 7, 2013 | 1:29 PM
TDSSD's Avatar
Default Mnually shifting and auto tranny
Thanks Fishing and Mark. I figured the Tow Haul mode in drive would be the way to go. When would you use the 3 Manual positions on the shifter?
George
Old May 7, 2013 | 3:25 PM
I've have used 1 or 2 when mudding so that i can be at high rpms and keep trans from shifting and bogging down. I guess the 3 can be used if you don't want to get into 4th to stay at a certain speed or rpms or something. I don't ever use 3
21bigblock
Mar 25, 2014 12:06 PM
lift_tech
Jul 5, 2010 11:18 AM
sojo
Dec 21, 2009 4:36 PM
markfothebeast
Jun 17, 2008 10:07 AM
