2003 tahoe gear selection
Old Mar 24, 2014 | 12:48 PM
21bigblock's Avatar
Default 2003 tahoe gear selection
Hello just a quick question to see if this is an easy fix. I have a 2003 Tahoe and when I start the vehicle and go to put it in drive I have to go to the 3 position then to the d position for the tranny to engage. If I go directly to Drive it does nothing. Any help is greatly appreciated
Old Mar 24, 2014 | 9:28 PM
Frank3's Avatar
It sounds like the linkage needs adjustment. If you go to 3 then you are going the next position past D compensating for the misadjustment. All other gear selections ok?
Old Mar 25, 2014 | 7:04 AM
21bigblock's Avatar
Yea everything else seems normal. It shifts fine it's just when you initially go to a forward gear.
Old Mar 25, 2014 | 7:06 AM
21bigblock's Avatar
It doesn't feel like a traditional linkage setup on this it feels as though it's an electronic shift. I was thinking maybe it's in the pr neutral safety switch???
Old Mar 25, 2014 | 12:06 PM
Frank3's Avatar
If you put it in neutral and try to start it, does the starter engage or is it locked out because of the safety switch?
TDSSD
May 7, 2013 3:25 PM
lift_tech
Jul 5, 2010 11:18 AM
sojo
Dec 21, 2009 4:36 PM
markfothebeast
Jun 17, 2008 10:07 AM
