transmission problem
Old Jan 26, 2013 | 8:47 AM
allistrac's Avatar
Wink transmission problem
I bought a 1997 chevrolet 2500 4 wheel drive that now will not shift out of 1st gear no check engine lite fluid looks and smells ok truck only has 80,000 miles 4l80e tranny any ideas would be welcome Terry
Old Jan 26, 2013 | 10:39 AM
Allan In NE's Avatar
Does the speedometer work okay?
Allan
Old Jan 28, 2013 | 8:58 AM
allistrac's Avatar
works part time
Old Jan 28, 2013 | 10:16 AM
Okay,<O</O
<O</O
The common denominator here is the VSS at the transfer case. 4X4 models use the output shaft speed of the transfer case, not the transmission output shaft sensor.
<O</O<O
That's sure where I'd start.<O</O
<O</O
Allan<O</O
Old Jan 28, 2013 | 3:56 PM
allistrac's Avatar
I just drove the truck and when the speedo and tach quit the trans will shift. When the speedo starts to work the trans down shifts and will not upshift. Is that weird? Help
Old Jan 28, 2013 | 6:22 PM
Has it ever shifted okay since you've owned it?
Sounds like someone swapped in a 4L80 in place of a 4L60 and didn't change the wiring.
Allan
Old Jan 30, 2013 | 12:16 PM
allistrac's Avatar
Smile fixed
I found that the voltage on the trans fuse would drop from 12v to 3v when the truck was running. After checking and by passing the original wiring the truck would shift and the tach and speedo would all work. Found the ignition switch bad. thanks for the help and suggestions. Terry
Coravir
Oct 26, 2019 3:28 PM
Gregg
Aug 4, 2015 9:08 AM
vger105
Dec 5, 2006 4:23 PM
Pbce888
Nov 10, 2006 12:09 PM
