transmission problem
I bought a 1997 chevrolet 2500 4 wheel drive that now will not shift out of 1st gear no check engine lite fluid looks and smells ok truck only has 80,000 miles 4l80e tranny any ideas would be welcome Terry
Okay,<O
</O
<O
</O
The common denominator here is the VSS at the transfer case. 4X4 models use the output shaft speed of the transfer case, not the transmission output shaft sensor.
<O
</O
<O
That's sure where I'd start.<O
</O
<O
</O
Allan<O
</O
</O
<O
</O
<O
</O
<O
</O
<O
</O
Allan<O
</O
I found that the voltage on the trans fuse would drop from 12v to 3v when the truck was running. After checking and by passing the original wiring the truck would shift and the tach and speedo would all work. Found the ignition switch bad. thanks for the help and suggestions. Terry
Coravir
Oct 26, 2019 3:28 PM
DSGB
May 29, 2013 8:54 AM
