transmission problems
Old Jul 12, 2011 | 8:21 PM
justinh14's Avatar
Default transmission problems
i have a 93 chevy silverado z71 with a 4l60e. my old one went out so i replaced it with another one and the shifter rod will not line up now. is there something i am missing.i need help figuring it out. i have tried everything i could think of.
Old Jul 14, 2011 | 7:14 PM
justinh14's Avatar
can no one help me or is it that dumb of a question cause i dont know the answer
Old Jul 15, 2011 | 12:32 PM
skeeter5's Avatar
Default Transmission help
I don't know your transmission, but am suggesting that you check with a local transmission shop.
This may be your best approach.
Good luck,
Old Jul 15, 2011 | 12:56 PM
slw210's Avatar
Pictures might help your explanation of the problem.
Do you have a Haynes or Chilton Manual?
Old Jul 21, 2011 | 10:20 PM
justinh14's Avatar
its the linkage from the frame to the tranny. its not lineing up now the front driveshaft is in the way
Old Jul 22, 2011 | 10:01 AM
OLD WRENCH's Avatar
Tell us about the replacement trans,is it for the year of truck you have? Is it for a 4wd? This could be important info.
Old Jul 28, 2011 | 10:01 PM
justinh14's Avatar
it came out of a 2wd, i had the output shafts swaped, it all bolted up like it was suppose to but the shift linkage isnt lining up. it is from a 1993 and it is a 4l60. i think it being from a 2wd has something to do with it
Old Jul 29, 2011 | 10:34 AM
RacerX's Avatar
You may need to get the linkage for a 4wd unit. I think there is an extra articulation there in between the transfer case. Go to LMCtruck.com and look for a schematic and corresponding part number to help you out.
Coravir
Oct 26, 2019 3:28 PM
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
amos221
Mar 11, 2007 1:41 AM
