Transmission Woes
Old Oct 22, 2014 | 7:04 PM
goadus's Avatar
Default Transmission Woes
I have a 1999 Silverado 4wd with 200,000 miles. While driving it this morning it made a weird noise like a klunk or something. I was driving about 60mph and had been driving all morning. After the noise it made I could give it a little gas and it would rev up and then "catch" gear. When I got to my destination it would not go in reverse. Any ideas what it could be? It's all good in drive just no reverse. I tried searching for this but no luck.
Old Oct 23, 2014 | 6:16 AM
Allan In NE's Avatar
Yes Sir,
The reverse input shell has stripped. The transmission has to come out for repair. About a $100 repair if you find the right guy to do it.
Allan
Old Oct 23, 2014 | 6:13 PM
goadus's Avatar
I read that 2nd and 4th gears will be out along with no reverse. So I tried it out today and sure enough no 2nd and 4th
Old Oct 23, 2014 | 6:27 PM
Yep,
That shell carries the torque of the over driven gears (2nd & 4th) along with reverse.
That shell will cost in the neighborhood of $40 and these shops are gonna try to soak you BIG bucks to replace it; $1700 to 2 grand.
The last one I did back in February, I charged the guy $200 and pocketed $100 of it for my 2 hours labor.
Allan
Old Oct 25, 2014 | 11:07 PM
goadus's Avatar
I have found a 4l60e from a 1998 and 1999 s-10. Will either one work in my Silverado?
Old Oct 26, 2014 | 12:44 PM
Hmmm,
Probably if you don't crowd it. The S-10 versions are built lighter, especially reverse. Make sure it is for a 4x4 also; S=2x and T=4x4.
Allan
Old Oct 26, 2014 | 6:19 PM
goadus's Avatar
Originally Posted by Allan In NE
Hmmm,
Allan
Thanks Allan, I'll be sure to check that.
Old Oct 26, 2014 | 7:50 PM
NealSS's Avatar
Actually the S-10 Trannies uses exactly the same clutches As the 1500 Not Weaker or stronger
Old Oct 26, 2014 | 7:51 PM
NealSS's Avatar
If its not a 4x4 just change the back housing from your tranny
ChevyMechaniac
Sep 12, 2006 2:38 PM
Andrew_350
Sep 10, 2006 12:03 PM
ShadowDrake
Aug 5, 2006 3:40 PM
fredtz
Feb 28, 2006 11:05 PM
Soulcrusher
Jan 24, 2006 10:17 PM
