Notices
truck idles rough
Old August 28th, 2010, 11:26 PM
chevyboi02's Avatar
Default truck idles rough
every so often my truck will start to idle rough and miss fire.. So far ive changed the ignition coils spark plugs and wires, the mass air flow sensor what else can cause a miss fire plz help
Old August 28th, 2010, 11:56 PM
therewolf's Avatar
Hi chevyboi02,
Welcome to the Chevy Forums.
Your vehicle is an 02? What's the mileage?
How are your injectors?
Old August 29th, 2010, 12:25 PM
DG Grumpy's Avatar
Have you tried to see if there is water in fuel? try running a few cans of dry gas & then Lucas injector cleaner with you next fill up. of course not all at the same time.
Old August 29th, 2010, 4:46 PM
chevyboi02's Avatar
i have 162,500 on it ive run a couple bottles or injector cleaner thru it every 3000 miles.
Old August 30th, 2010, 12:08 AM
2wd-K5's Avatar
have you done a compression test? a bad valve is more eveident at an idle than when running at speed
Old August 30th, 2010, 8:27 AM
99ChevyZ71's Avatar
I've been informed that BG, Redline and other petroleum-based injector cleaners work better than alcohol-based cleaners. They are less harsh on seals and less likely to corrode metals.
Old August 30th, 2010, 6:15 PM
chevyboi02's Avatar
i had a compression test done maybe a month ago and all was good.
Syris71
February 27th, 2012 8:31 PM
Cristobal Estrada
July 16th, 2011 5:30 PM
crwalker2
November 26th, 2010 11:41 PM
dkerns2004
April 6th, 2008 10:16 PM
Quick Reply: truck idles rough
