Truck shifts without brake/ can't remove key
Old Dec 20, 2012 | 5:17 PM
jzimm's Avatar
Default Truck shifts without brake/ can't remove key
I can't remove the key form my 97 1500. The key will start the truck and shut it off, but will not turn back far enough to remove it and the Park light indicator stays on. Also , I can shift through all the gears without touching the brake.
Thinking its either the Park/neutral switch or the brake interlock, but most of the problems people have are with it not being able to shift and I have the opposite problem. Looking for advise on where to start troubleshooting
Thanks
Old Dec 22, 2012 | 10:13 PM
go-part's Avatar
Former Sponsor
Well the key not coming out of the ignition is the sign of a bad lock cylinder. The whole gears shifting without the brakes needing to be pressed is the sign of a bad brake interlock (park lock system).
pdrayton
10
May 5, 2024 2:27 PM
dj pc era
Astro
May 27, 2011 9:57 PM
sixpack_sid
Jul 30, 2009 8:56 PM
rick12667
Cobalt
Jun 18, 2009 8:12 PM
mystikal1000
Jan 21, 2008 12:18 PM
