truck trying to start when reconnecting the battery
Old Nov 1, 2014 | 9:39 PM
silveradoman76's Avatar
Default truck trying to start when reconnecting the battery
i just replaced the starter on my 01 silverado and i also replaced the clutch safety switch and now when i reconnect the battery the truck is trying to start
Old Nov 2, 2014 | 1:18 AM
here are some possibilities:
-you hooked something up wrong when you installed the starter or clutch switch
-the starter is faulty
-the ignition switch is supplying power to the starter solenoid when the key its in the off position
- the clutch safety switch isn't working right, there should not be power going through the switch...the switch should be open unless the clutch is depressed.
I would disconnect the starter solenoid wire at the starter, connect your battery. if it doesn't crank by itself, that wire is shorted to power or you have a bad ignition switch.
The Red Tsar
Jul 18, 2014 9:22 PM
knucklebust
Mar 2, 2012 12:47 PM
chrishilary93
Oct 18, 2009 9:55 PM
thdrill
Oct 1, 2007 10:17 PM
