Truck won't go in park!!!
Old Dec 23, 2012 | 6:33 PM
chevycheetah's Avatar
Default Truck won't go in park!!!
So I rebuilt my engine and got it mounted and bolted up to the transmission. Today I moved the truck by pushing it so I threw it in neutral and when I put it in the spot to have it in park, it stayed in neutral. Any ideas on what could be wrong? I had it in park before but now it just won't go.
Old Dec 23, 2012 | 10:17 PM
MDTAHOE's Avatar
Professional Mechanic
Do you have the torque converter bolted to the flywheel?
Old Dec 24, 2012 | 6:01 AM
Yeah I have it all bolted up.
Old Dec 24, 2012 | 7:45 AM
Allan In NE's Avatar
What the heck are ya working on?
Allan
Old Dec 26, 2012 | 5:20 PM
1985 350 with I believe a 700r4 transmission.
Old Dec 26, 2012 | 6:19 PM
panfry350's Avatar
does the the shifter feel like the transmission is in a bind or is it loose like the shifter goes to park but the transmission wont?
Old Dec 27, 2012 | 8:40 AM
I'd bet you mounted the bell-crank upsidedown when you put it all back together?
Allan
Old Dec 27, 2012 | 8:28 PM
The shifter feels basically normal, maybe a little more loose.
Old Dec 27, 2012 | 8:59 PM
panfry350's Avatar
might check ur linkage to from the steering to the trans or if the engine is running and the truck will moe on its own then check the trans modulator maybe out.
Old Dec 28, 2012 | 11:05 AM
I'll check the linkage and see if i can find anything.
structures282
Mar 12, 2021 10:33 AM
gmlover
Corvette
Aug 23, 2009 6:33 AM
deere1
Jul 29, 2008 3:14 PM
catboater
Astro
Mar 3, 2008 6:33 PM
cmteter
Jan 3, 2008 10:53 AM
