truck wont start
Old Feb 8, 2013 | 5:01 PM
  #11
kevinkpk's Avatar
Originally Posted by acer9876
how would i go about doing that?
and i just double checked my fuel pressure. and i when the key is turned to acc, it quickly builds up to 60psi, and holds for maybe 1/10 of a second. then bleeds all the way back down, almost as fast as it built up.
Use an ohmeter, I guess you don't have one. Fuel pressure should hold for longer than you are saying.
Old Feb 9, 2013 | 11:23 AM
  #12
acer9876's Avatar
yes, i have one. it came out to be 1620 i believe
and i know it should hold longer, but ive read something about a bad sensor could cause that?
Old Feb 9, 2013 | 11:42 AM
  #13
acer9876's Avatar
also note that everything was running fine before i pulled the engine apart. the reason for me replacing the crankshaft and oil pump is because my oil pressure droped to 2 while i was driving, and i also had a knock, which was spun bearings
Old Feb 12, 2013 | 4:36 PM
  #14
acer9876's Avatar
im back to the crank sensor. it reads 5v when the engine is not being cranked. for about the 1st second of cranking it averaged .2v. then 0v. is there a way to find out what the spacing's supposed to be between the sensor and the pickup.?
Old Feb 12, 2013 | 4:50 PM
  #15
kevinkpk's Avatar
1620 ohms sounds very high, that will affect the amplitude to the pcm. Do you have a meter that will read hertz? I don't know the spacing on the crank gear the pickup is reading. The voltage you state is looking at cranking with a digital meter, does your meter have an analog bar?
Old Feb 23, 2013 | 10:41 AM
  #16
acer9876's Avatar
thank you for all your help, i didnt do those last tests that you mentioned. but i got my truck to start. its an odd thing... what happened was, i swapped my not working crank sensor with another vehicle that was running. and immediately after, with no further modifications. both vechiles started just fine.
sleepingciv
Jul 25, 2020 1:03 PM
willys473
Sep 25, 2009 5:34 PM
ems_mike85
Jan 3, 2008 8:07 AM
guitarbeast99
Jun 19, 2007 6:39 PM
sbbrown
Mar 3, 2007 9:16 PM
