Old Aug 10, 2015, 7:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Turn OFF Check Engine Light?
Old Dec 1, 2007 | 6:28 AM
Bolander's Avatar
Default Turn OFF Check Engine Light?
[hr]Besides having the codes cleared with a scan tool, what is the DIY procedure for turning off/resetting the check engine light?
Old Dec 1, 2007 | 6:30 AM
Bolander's Avatar
Default RE: Turn OFF Check Engine Light?
[hr]Forgot to mention, above is in regards to a 1997 Silverado 2wd 5.0L.
Old Jan 13, 2008 | 12:41 PM
tedco21's Avatar
It has to be cleared with a scan tool.
Old Jan 14, 2008 | 6:56 AM
tedinindy's Avatar
You gottafigure outwhat caused the check engineand fix the problem. Depending on the code or codes involved once fixed the light will stay off. A few codes will require a determined number of on/off "cycles" without error before it will go out. You can always erase codes by disconnecting the battery for at least a half hour. That resets the PCM. The check engine light will come right back on and stay on till you fix whatever iscausing it
Old Jan 12, 2013 | 6:32 PM
cffcjoker's Avatar
I can reset service engine lightby removing the two ecm fuses and turning key on for ten minutes reinstall fuses start truck this is on a 2000 silverado worth a shot
Old Feb 7, 2018 | 8:14 PM
all depends on where the information is stored. A LOT of new vehicles will not clear with a battery disconnect...keep alive memory. For the ones that do clear...you could also lose the engine and transmission adaptive learn memory. the scan tool may not be the only way but it is the best way.
Old Feb 14, 2020 | 4:09 AM
M, Calloway's Avatar
Default Clearing the SMS light on my dash 04 C which one is it to removing cute ischium right
Which to of the ECM fuses.. I've an 04 4.8 half ton Silverado ls.?
redrotor
Cobalt
Aug 29, 2019 8:38 PM
2001impalaflip
Mar 22, 2013 12:23 PM
psd7.3
Dec 22, 2010 8:23 PM
Engam
Nov 7, 2010 10:21 AM
Mr. Vann
Nov 25, 2009 7:24 PM
