VIDEO sticky lifter? help please.
Old Aug 9, 2012 | 9:40 PM
J.b. ONeill's Avatar
Default VIDEO sticky lifter? help please.
i changed oil last night and ran engine today and noticed this tick, not quite sure what it is or how to fix, any help would be apreciated. ticks mostly when on the throttle. thanks a ton!
ticking vortec 8100 - YouTube
used mobile one 0w-40
Old Aug 9, 2012 | 10:26 PM
jesse06's Avatar
ohhh damn that sounds bad. not sure if starting small will help there buddy.
Old Aug 10, 2012 | 8:31 AM
shamrock246's Avatar
Do they spec 0w-40 for marine use,my 5.7 vortec in my boat specs 15w-40 above 50degF,other than that sounds like a bad lifter
Old Aug 10, 2012 | 8:45 AM
Allan In NE's Avatar
Pull the belt and see if the noise goes away.
If not, think ya might need an engine.
Allan
Old Aug 10, 2012 | 6:25 PM
MDTAHOE's Avatar
Professional Mechanic
Sounds like the timing chain slapping. Hard to tell from a video. Could sound completely different in person
Old Aug 10, 2012 | 7:19 PM
kevinkpk's Avatar
FWIW Lifter
Old Aug 13, 2012 | 2:18 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Would you please send the last 8-digits of your VIN, so I can look into this further?
Louis
GM Customer Service
Old Aug 13, 2012 | 6:13 PM
96 Junk That Moves's Avatar
Change the oil again and use the factory recomended oil 5W-30. Also do you have the right filter? 0w-40 is the wrong oil...better than no oil but wrong just the same. imho.
My 96 5.0 has 267k on it and all I've ever used is Mobile-1 5W-30. engine is quiet and uses no oil between changes.
Old Aug 13, 2012 | 11:20 PM
mastercraft reccomends 0w-40
Old Aug 14, 2012 | 6:58 AM
MDTAHOE's Avatar
It is in a boat. They use different weight oil then a truck motor. Even though it is a 8.1 GM motor it is a different beast.
64Impala4doorpost327
Aug 12, 2015 2:18 PM
Minimex88
K5 Blazer
Jan 30, 2014 5:13 PM
p8ntballa9362
Nov 25, 2013 10:52 AM
ddog96mn
Aug 9, 2012 6:52 PM
AZSCTACO
Aug 20, 2010 4:09 PM
