water in door
Old Feb 3, 2016 | 8:12 AM
  #11
SteveWojo's Avatar
Default Just for some reassurance for people.
As I stated I've had this problem. Mine WAS NOT clogged drains. I checked and rechecked the drains they are not clogged. It has to be bad window seals.
Old Feb 4, 2016 | 7:30 AM
  #12
Originally Posted by SteveWojo
I know this is an old post but I have a 07 that had the same exact problem had it happen to my driver side front and rear doors, I checked the seals and they seem fine, I pulled the plugs from the base of the doors to make sure the water would drain and left the plugs out. I hasn't happend since.
no window sill is water tight. if they were, drains and water shields would not be needed. Even with no sill, properly function drains will not allow water to pool in the door.
Old Feb 4, 2016 | 7:32 AM
  #13
Originally Posted by seamuskennison
Not sure I understand how they're clogged since they drain as soon as I pull the molding out.
Either bend the sheet metal drain hole to enlarge it or modify the lower weatherstrilp to stop t from blocking the flow out of bottom of the door. You should be able to figure it out without throwing parts at it.
Old Mar 18, 2023 | 10:52 AM
  #14
Nana0304$'s Avatar
Default Leaking rear crew cab door
I have a 2010 Silverado Crewcab LTZ. Rear door has leaked and filled up from day 1. Dealer claimed could find nothing. Rear speakers fried and they did nothing.
Deuce22
Jun 26, 2010 10:21 PM
Fightn17
10
Apr 8, 2010 12:45 PM
BMoTahoe
Oct 5, 2009 9:46 AM
TBFire
Jun 29, 2009 6:54 PM
minnesotan
Apr 24, 2008 2:06 PM
