What size tire will fit this rim?
Old Jul 24, 2010 | 3:49 PM
Dee74's Avatar
Default What size tire will fit this rim?
I have a 2006 Silverado 1500 WT Extended cab. I am thinking of putting a leveling kit on. If I use the factory rim which is 17 x 7.5. What are some of the bigger tires that will fit this rim? I like my rims and would keep them if they could fit some larger tires.
Old Jul 24, 2010 | 5:09 PM
s34n's Avatar
you could probably fit 305s at the max with potential rubbing. 285 should be comfortable and 295 should be cutting it close.
Old Jul 24, 2010 | 5:20 PM
Dee74's Avatar
Another question would the 285s fit in the factory suspension or would they rub?
Old Jul 24, 2010 | 5:23 PM
s34n's Avatar
im pretty sure the 285s wouldnt rub. the 295s might.
Old Jul 24, 2010 | 11:40 PM
Blindsight's Avatar
285's are a pretty safe bet. That's what I have on my truck and I have plenty of room for more if I wanted. Though, my truck is a 2500 so it may sit a little higher (though I'm not sure). You could probably go on up to a 315 if you wanted, but they would cause some rubbing when turning tightly, especially over bumps. Potentially, of course.
rcproductions
Sep 20, 2013 11:46 AM
rickp
Dec 6, 2012 10:33 PM
rickp
Nov 9, 2012 7:05 PM
bruisr
Sep 11, 2012 9:08 PM
Nickoneasternshore
Feb 9, 2011 7:30 PM
