Wheel Offset 1998 Silverado
Old Mar 29, 2007 | 1:54 PM
jaymitchell01's Avatar
Default Wheel Offset 1998 Silverado
Hi all - I have a 1998 Silverado Z71 and looking to do a wheel and tire upgrade. Right now my wheels are stock, and want to go to a 17x8 and run 285/70/17s.
Question is, what are my stock wheel offsets, and what offsets should I go with on the new rims to avoid rubbing, etc?
Thanks!
Jason
Chesapeake VA
1998 Silverado Z71
1991 Corvette ZR1
1997 Dodge Viper GTS
Old Mar 30, 2007 | 4:34 AM
kcb37's Avatar
Default RE: Wheel Offset 1998 Silverado
Call the parts departement at a dealership with your vin they should be able to tell you, or if you get new rims from a good shop they should be able to tell you too.
Old Mar 30, 2007 | 3:14 PM
Dondobe's Avatar
Jaymitchell01,
Be careful of how much offset you have and make sure your wheel and tire dealer knows what they're doing. I had a problem with too much off set and it created a bad vibration problem. If we used the standard offset the vibration would go away.
If you use a reputable dealer, ask them if it creates a vibration problem if they will replace the wheels until they get the offset right!!
Good Luck, Dondobe
lph008
Mar 9, 2014 7:15 PM
bruisr
Sep 11, 2012 9:08 PM
azsheriff
Sep 18, 2007 3:35 AM
rummikube
Apr 25, 2007 11:18 PM
biglg
Oct 17, 2006 10:38 PM
