Where to find a clockspring?
Old May 1, 2012 | 11:40 AM
Nathan.'s Avatar
Default Where to find a clockspring 05 Silverado CC?
Hey, I have a 2005 Silverado Crew Cab with the steering wheel controls. I have been looking a lot online and all I can find are the ones that specify "w/o accessory controls". I opened up my clock spring hoping I could just solder the cable back on but I found out that it utilizes a ribbon cable which is almost impossible to strip the insolation off of. I am a little bit sceptical about picking one up from a junk yard since I dont want to pick one up with the exact same problems. Any ideas?
Btw I like what I have seen of the sight a lot!
Old May 1, 2012 | 3:12 PM
RacerX's Avatar
rockauto.com
or autozone or advance or pepboys or the dealer as a last resort.
Old May 1, 2012 | 6:37 PM
Doug Roberts's Avatar
Most yards will give you like 15-30 days if u ask they will replace it
Old May 2, 2012 | 6:28 AM
Nathan.'s Avatar
Originally Posted by RacerX
rockauto.com
The dealer is looking like the only option out of those two. Thank you though.
I never thought about that! Thanks!
Old May 2, 2012 | 11:21 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Nathan.,
You may also consider checking out the GM Parts Direct website. They carry clockspring with steering wheel control for Silverado Crew Cab.
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
Old May 3, 2012 | 7:41 AM
RacerX's Avatar
I wouldnt trust a junkyard clockspring and as far as I know they wont let you return it. If they pull it, maybe. If you pull it, doubt it. Besides you dont know why the car is in the junkyard in the 1st place. The clockspring may have already been used. What was wrong with the clockspring anyway? If your car is 7 years old it isnt normal for a clockspring to go bad. That usually happens after 10 years.
Old May 4, 2012 | 12:35 PM
Nathan.'s Avatar
Originally Posted by Chevrolet Customer Service
Nathan.,
Louis
GM Customer Service
Thanks a ton! Would you happen to know the part number for the clockspring with steering wheel controls?
tlaura21
Feb 9, 2011 8:01 PM
vroom2559
Dec 2, 2010 7:06 AM
2000Impalaspeeder
Nov 3, 2010 2:47 PM
89blazer89
K5 Blazer
Dec 6, 2006 5:41 PM
dalis
Feb 2, 2006 3:50 PM
