Wierd sound when turning wheel
Old Apr 21, 2010 | 9:40 PM
tsduke's Avatar
Default Wierd sound when turning wheel
05 Silverado Z71
Not sure how to explain this sound, but the last couple weeks I get sound when turning wheel slower. Like when back into a spot. The best I can describe the sound is like something might be dry. It doesn't sound like a power steering or belt sound.
Any ideas.
Old Apr 21, 2010 | 10:37 PM
s34n's Avatar
where is the noise coming from?
Old Apr 21, 2010 | 10:39 PM
Mille Racer 69's Avatar
did you check the level of your power steering fluid?
Old Apr 21, 2010 | 10:52 PM
tsduke's Avatar
I'm not sure exactly. seems like not far down from the wheel. I kinda feel it in the wheel.
I didn't check ps fluid yet cuz it didn't seem like that type of sound.
Old Apr 21, 2010 | 11:32 PM
s34n's Avatar
does it sound like it could be coming from between the firewall and wheel? also does it sound like a squeak when turning the wheel?
Old Apr 22, 2010 | 2:26 AM
racerx55's Avatar
mine does the same thing, makes a pump whine buzzy vibration in the steering wheel, only when turning left., or almost like a dry tie rod / ball joint creek, but it can be felt in the steering wheel more than anything.
not sure what the cause is yet but its been doing it for a while and only seems to be at very slow speed when the pump has to work harder.
if i figure it out this weekend ill be sure to post back. fluid is a little dark looking, so im gonna try changging it and see what happens
Old Apr 22, 2010 | 6:17 AM
tsduke's Avatar
I think its past the firewall.
Old Apr 22, 2010 | 7:29 AM
tsduke's Avatar
PS fluid level is normal.
Very slow speeds is the only time it does it and not always. I swear sometimes I can feel it in the breaks but not sure.
Old Apr 22, 2010 | 2:00 PM
ffmed6134's Avatar
hub bearing issue maybe?
Old Apr 22, 2010 | 2:27 PM
tsduke's Avatar
I don't think so, but who knows. I may just need to have it looked at.
