Will it fit?
Old Aug 5, 2009 | 1:31 AM
suzuki-guy's Avatar
Default Will it fit?
Will the TBI unit off a 1989 fit on my 1995? I found one for twenty bucks and it would not hurt to have a spare!
Old Aug 5, 2009 | 4:23 AM
92chevysilvy's Avatar
Classifieds Moderator
TruckForums Liaison
For some reason i feel like it won't, But I don't remember why
Old Aug 5, 2009 | 7:45 AM
MDTAHOE's Avatar
Professional Mechanic
Yes and no pre 1990 has a throttle cam 1990-1995 are the exact same. It will bolt on but I am not sure if you will be able to hook up the cables.
http://www.holley.com/502-9.asp
Old Aug 5, 2009 | 9:14 PM
lukemoore646's Avatar
if anything buy it and try it, i bet some of the parts swap and maybe it will get rid of the drop of rpm when you push the clutch in
Old Aug 6, 2009 | 11:55 PM
98white5.0's Avatar
I figure it will work. How does the top of your air cleaner on your stock one fit on? Is it two wingnuts or one? What about the one you are looking at? Is it one or two? For some reason I'm thinking the 94 and 95 tbi had two wingnuts and the pre 94 was only one. Don't know if that will affect anything but thought I would add it anyway.
Old Aug 7, 2009 | 12:34 AM
suzuki-guy's Avatar
It use to have two but now it has two for my cold air intake.
Old Aug 7, 2009 | 7:28 AM
mudmaniac's Avatar
Ride of the Month
May 2009
It will bolt on but the throttle linkage is different and the plug connector for the tps is different, the top half will be the same and you could swap lots of parts.
Old Aug 7, 2009 | 7:32 AM
suzuki-guy's Avatar
So basically the only thing the same is the injector pod? The linkage is not removable?
SteveI
Sep 7, 2006 1:59 PM
Cavigurl85
Aug 16, 2006 8:33 AM
Cavigurl85
Aug 6, 2006 10:12 PM
03z71Tahoe
Apr 19, 2006 1:17 AM
adjmcloon
Apr 11, 2006 10:26 PM
