Won't run, HELP
Old Sep 16, 2013 | 10:03 PM
Orgrabbit's Avatar
Default Won't run, HELP
I replaced the intake gasket, went well. Complete new distributor put in, but the only way it will run is by pouring gas down the throttle body . It tries to Start on its own but won't. Could it be fuel pressure regulator?
Old Sep 19, 2013 | 10:43 PM
therewolf's Avatar
Hi Orgrabbit,
welcome to the Chevy Forums.
OK, so, vintage pickup, assuming it's an eight cylinder, it's probably
a 350?
What year is it?
Old Sep 20, 2013 | 7:28 AM
Orgrabbit's Avatar
Sorry should have put that info in. I managed to get it going last night, after replace ing the complete spider assembly. Now I'm getting " camshaft to crankshalf correlation " code. It runs smooth. It's a 1998 with 5.7 . Any ideas on the code?
Thanks
Old Sep 21, 2013 | 5:09 AM
therewolf's Avatar
Usually, that would concern timing, but it's not that simple.
You may have the distributor gear off by a tooth or two, at
the cam. Or the timing chain could be stretched and have slipped,
or timing gear teeth broken. Some of the old factory L blocks used
Nylon timing gears.
What is the mileage? Original engine? Has it been run hard?
Old Sep 21, 2013 | 10:34 AM
GMtruckGuy's Avatar
You may have the distributor gear off by a tooth or two, at the cam.
What he said is the most likley 2 things.
jkemp101
Aug 28, 2013 11:44 PM
larryntripp
Oct 23, 2008 8:13 PM
mandara43
Apr 1, 2008 7:31 PM
icandoit
Sep 3, 2007 8:46 PM
sbredeson
Oct 2, 2006 5:34 PM
