Won't start, sometimes?
Old Jun 9, 2013 | 1:04 PM
T-Craft's Avatar
Unhappy Won't start, sometimes?
I just purchased this truck a month ago and only drive it on weekends, runsand starts great except occasionally it won’t start? <o></o
I just ran the OBD codes with my code reader and all I get is C267 for theABS light on the dash. So I purchase afuel pressure gauge and sure enough when it won’t start there is no fuelpressure? So I couldn’t get it to start Saturdayfor about 5 hrs. and this is much longer than usual. I proceeded to start pulling the gas tank protector shell off of the tank and reachedup and wiggled the wire/connectors around to the fuel pump and tried to start itagain and it finally started and indicated 50PSI of fuel pressure. Now I can’t get it to fail again in starting untilI need to use it to run some errands, come out of the store and then it will not start again after it has been sitting 15-30 minutes, but this occurs intermittently. What’s the problem, an intermittent fuelpump??? <o></o
I have swapped like relays in the truck and the issue continued so it’s notthe fuel pump relay.<o></o
I have pulled the vacume hose on the fuel pressure regulator and it is not leaking fuel from it, so I presume that it’s not the cause, even though when itstranded me the first time at the store I removed and replaced the vacume hoseand the truck started? I hate intermittent electrical issues; anyone fought this same type of issue???
Thank you for any help in advance.
2001 1500 Silverado LS, 4x4
5.3L auto 135,000 miles
Old Jun 9, 2013 | 4:56 PM
Check for loose connections at the fuel pump and corroded wires going to the pump. It is usually a bad ground connection.
02suburban
Jan 19, 2015 12:33 PM
User 121922
Sep 3, 2013 3:29 PM
98lumina
Nov 6, 2012 1:31 PM
c.lee911
Jul 26, 2011 7:37 PM
smd900
Astro
Apr 2, 2011 9:57 AM
