your break in procedure??
sbc 421 stroker. 400ci .030 over 3.875 stroke 6.00 rod flat tops iron heads 2.02 valves flat tappet cam stamped rockers. heard many of break in ideas, my first break in. best one i have heard is
--start, set timing, check for leaks, let idle for 15 min, bump to 2500 rpm for 15 min then just drive it easy with varying rpm and load
anyothers??
thanks
been my project for past 3 years![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
anyothers??
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Site Ambassador
Pre-lube the engine using an oil pump priming tool.
Follow the recommended cam break-in procedure: holding the rpm's between 2-3k for 20 minutes.
Drain and replace the oil and filter.
Then drive the car to break in the rings. Driving puts a load on the rings, which is what pushes them out against the cylinder walls for proper break-in. Just running the engine in the garage is a light load and doesn't give the same effect as driving.
Don't baby the engine, but don't beat on it either. And yes, drive it at varying speeds and rpm's.
It's in my mud truck so driving it down the road really isn't an option. Also during the priming I have heard to turn the crank with a socket to help oil mains?
The reason for draining the oil after 30 minutes or so of running is to examine the drained oil for water. So don't waste $$ on synthetic oil for the first startup. Any thin 10-20W oil will work fine. I use to put the oil if a few glass jars and let it sit overnight. If there was any water in it, the water would be at the bottom and I could see it with a light.
94burbin
December 11th, 2012 11:32 AM
jseabolt
August 17th, 2009 4:43 PM
