Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2006 Aveo 4-1600 1.6
Old May 7, 2020 | 3:02 PM
Jerry32's Avatar
Default 2006 Aveo 4-1600 1.6
Hi,
I have an Aveo with 139K miles. I've had various issues the recalls-DRL Module, throttle body, had alternator replaced. And I have a ripped intake boot, front door locks both fell inside . But a few days ago when I started the car there was smoke coming from the front of the car.
I don't drive too much-but seems like a serious issue and wondering what the issue is. This is a short video-3 seconds but hope it works. Thanks so much!
File Type: mov
Old May 8, 2020 | 8:57 AM
check for oil seepage from the valve cover. if oil seeps out onto the hot exhaust manifold it will smoke. this does have fire hazard potential. pretty easy fix.
if it just rained or you washed the engine its just water burn off.
as a none related maintenace issue....make sure the timing belt have been done. if it hasn't, buy the timing kit with new pulleys, water pump and belt. don't neglect this.
Old May 10, 2020 | 4:05 PM
Jerry32's Avatar
Thanks for your reply.The Alternator & Drive belt were installed in late 2018 fyi.
Old May 11, 2020 | 12:02 AM
alternator drive belt is not a timing belt.
Old May 15, 2020 | 3:55 AM
Jerry32's Avatar
Ok thanks
Harpless
Sonic (Aveo)
Oct 9, 2013 8:32 PM
breannanoahmason
Sonic (Aveo)
Aug 29, 2013 5:44 PM
sergiuhusca
Sonic (Aveo)
Mar 15, 2012 12:23 AM
mwatters
Sonic (Aveo)
Sep 24, 2011 6:54 PM
INKOGNITO3
Sonic (Aveo)
Aug 9, 2009 6:30 PM
